Led_67
Mar 06, 2017Explorer
sasquatchgeoff wrote:
For some reason, my driverside-front jack is locked up in the retracted position. Took the motor off, the shaft and bevel gear will not turn. Worked fine when I last loaded. Drove home parked, went out to unload, and jack shaft will not rotate.
Is there some trick I am missing, or do I need to start looking for a jack?
The question that I have is why is the bevel gear jammed, It obviously went up fine so either something has gotten into the gears or the shaft is jammed within the leg itself.
I would attempt to lower the leg manually before disassembly of the gears as well as checking the leg housing for debris as well as true.
Good luck
44,027 PostsLatest Activity: Apr 19, 2019
