akcooper9
Mar 26, 2018Explorer
bamafeaver wrote:
Does anyone have a auxiliary fuel tank for a gasser. If so what kind. 2500 HD 6.0 gasser pull a fifth wheel. Thanks
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/26924844.cfm
I put an RDS in my Gas truck 5 years go. It worked perfect. As mentioned you will need to pump it to the main tank to be legal. Make sure you buy a solenoid valve to cut the flow when you turn off the pump. I also tied the rds tank vent to the evap system on the truck to keep pressure equal and no check engine light.
PM me if you have questions
44,025 PostsLatest Activity: Feb 18, 2025
