patnchris wrote:
I find this very interesting. I am towing the trailer in my sig. It is around 7800 -8500 lbs. I tow with a 2007 F150HD, 5.4. 373 gear. I tow with OD off at around 65 mph and almost never use cruise. In approx 6000 miles towing, over the last two years, I am averaging right at 10 mpg. I did switch all lubes to synthetic, but wouldn't think it would make that much difference. Is it possible that keeping the 5.4 closer to it's power band makes a difference. Usually runs around 2500 rpm.
Have you checked to make sure your odometer is accurate? I check my odometer using the mile markers on the interstate. I once had a new Chevy that had an odometer that logged more miles than I had actually traveled. I thought I was getting great gas miles until I figured out the odometer was not correct. It appeared to be setup for a truck with 17" tires and my truck came with 16" tires.
