I had a recurring problem with toilet paper clogs in my travel trailer. I tried various products to correct the problem with very poor results. I then went to wally world and bought three items.
First was a watering wand about 3ft long with an on/off valve just below the hose connection. The terminal end produced a water shower effect. The pipe was bent about a 45 degree angle near the shower end.
The second was a hose connection sometimes call a concentrator. This fitting narrows the stream down to about a pencil thickness to give a higher pressure stream. This fitting also had an on/off valve that really isn't necessary. If you can find one with out the valve it would be better. The valve handle tends to collect debris during the clean out process.
The third was nylon thread tape.
I removed the water shower head and using tread tape, added the concentrator nozzle. Because of a large water leak found the first time I tried to use the assembly, I tread tapped the hose connector where it threaded onto the wand.
With the use of a split tree, I bent the pipe a wee bit more to assist in inserting it into the tank. The first two times I used it debris and fluids were right below the base of the toilet. I inserted the assembly into the tank with the black tank discharge valve open and water turned off at top of wand, gradually opening the water valve and started rotating the wand back and forth trying to drive the products towards the outlet pipe. After fluid level dropped, used the wand to push the mound under the toilet towards the drain. Darn thing worked good. Showed it to my RV neighbor and he built one for himself and also has had good results. He had the problem because he insisted on using regular toilet paper.
Be aware of a tendency to receive splash back if you aim the stream directly towards solid or semi solid surfaces. Always try the use the stream at an angle (don't ask me how I found this out).
