itsjustjer
Aug 02, 2019Explorer
drsteve wrote:itsjustjer wrote:
I feel like I should clarify my original post to inform that I’m not trying to manipulate the hitch weight, but find one that is built/configured by the manufacturer to have as close to 10% hitch weight as possible. One camper with a 5k dry weight has a 500lb hitch weight (when dry) and another 5k camper has an 750 hitch weight (when dry). So that tells me the manufacturer built that 750 hitch weight camper with more weight toward the front obviously. Both 5k lbs, but one has 250lbs more payload on the truck before you even load it up. The disparity only gets greater as the loaded weight of the camper gets greater. What I’m asking in my original post is if anyone knows of a camper that (by design of the manufacturer) has as good of (or better) hitch weight ratio than the 272BHS. Not looking for ways to lighten or misappropriate the weight in a way that was not designed by the manufacturer.
You are assuming that the manufacturer's dry tongue weight number is accurate. There is no assurance that this is the case.
Pardon me if I come across as frustrated with this post, but if we can’t depend on ANY numbers from the vehicle or the RV manufacturer to be correct, then how has anyone ever purchased a vehicle and RV and known they were within their limits until after the fact?
Maybe we’ll just rent whatever model we’re thinking of buying and take it to the scale. Even then, that particular trailer isn’t going to weigh the same as the specific one we’ll be buying.
44,056 PostsLatest Activity: Jan 12, 2026
