Kayteg1 wrote:
...............zip.....................I installed Chinese diesel heater in my latest conversion. They are very energy saving and quiet.
When propane heater makes coming on and off rocket, diesel heater adjust the speed depends on heat demand, idling slowly when heat is on low demand.
Have seen motorhome owners installing it with small tank that comes with it. When some smell can be an issue, you are avoiding low temperature issues and can fill it with 50-50 mix of kerosene/diesel.
This is interesting and I would like to know more if you don't mind please?
Could you post photos of your installation?
Where did yo locate the Diesel fuel tank, or are you using the main Diesel fuel tank?
I assume there is no propane heater at all in your conversion?
Is it a van conversion or...?
What size unit is it kW or BTU?
Any idea how many amperes it draws when it's operating (at 12 V)?
Any amp. draw when it's off (I hope not!)?
I have a two speed propane heater in my slide-in camper and it is still pretty noisy at the low speed.
Any information would be appreciated.
