HotelOne
Nov 27, 2017Explorer
dave17352 wrote:
I think you will have to remove the cooling unit. If you remove the door frame you will gain a little but probable not enough. I recently installed a 12 volt danfoss compressor fridge from nova kool. One of the things that was great is they had many models that would fit through the door. I had to take the cooling unit off of the fridge I was removing. I would return that fridge and go 12 volt but that's just my opinion. I really think you will have a issue with the fridge you have ordered. Only because of the fact that I have all ready been through this.
Thank you for this, with the unit over 3" wider than my widest entry I think it'll be a no-go. I'm sure I'll be able to demo the old fridge with enough crowbar and hacksaw applied. I did find the Nova Kool fridges - does yours really cool well enough in 12V? Should I get a 120/12V unit? Does it auto-switch or manually switch? TIA!
44,030 PostsLatest Activity: Jan 21, 2025
