dirtengineer
May 19, 2011Explorer
It should be 2 psi below your cut in pressure - that is the pressure where the pump turns on, not off. If that is a Shurflo 2088, then you should set the pressure at 23 PSI. Having the pressure set too high will reduce the volume of water that the accumulator holds and lower the overall performance.
44,026 PostsLatest Activity: Mar 03, 2025
