There is a check valve in that fitting to prevent that from happening. Turn off the pump. Open a faucet to relieve any pressure in the system. Take the eraser end of a pencil. In water fill connection you will see a plunger looking piece. Press it in and out a few times. Turn on the pump If you're lucky, the leak might stop.
