MikeJulieGDImag
Mar 20, 2018Explorer
I suggest going back to the scales and weighing multiple times with different adjustments on your WDH. We tow with a 2013 Expedition EL and on one trip I noticed it felt very 'floaty' to the point it was a little nerve racking. Your feeling 'floaty' because you have removed quite a bit of weight off the steer axle. Go back to the scales loaded as if you were going on a full trip and hit the scales multiple times doing different adjustments until the weight on your steer axle is almost back to stock without the trailer hooked up. I did this and noticed the setting I was using when I had the 'floaty' feeling I was off almost 300 lbs on the steer axle from stock. I weighed up multiple times and go the adjustment on the WDH to where the weight on the steer axle is within 40 lbs of stock. No issues since.
44,025 PostsLatest Activity: Feb 18, 2025
