Thank you for your responses. When the rain stops, I'll check the weight capacities. Would you use only one sway bar? Are they hard to install? I guess I'll need to check on the Honda thing. Not quite understanding that part, but I'll need to find out more. I mainly want to eliminate whatever sway I can, since I still need to get used to towing it. The previous owner never used one, and said I wouldn't need one, but I don't have his experience, and would rather play it safely. I had figured on putting supplies in the bed of the truck. Is that not advisable?
