Dick_B wrote:
We have the Equal-i-zer and occasionally have sway but it is manageable. If you have the Hensley it is IMPOSSIBLE to have sway. What are you willing to settle for? How much is the current truck and TT worth. If it is at least $100K then $2500 is less than 3% if my math is correct.
I'd search this Forum for Hensley and read all about it. Is hitching a problem?
Hitching is not a problem nor is the sway but then I have yet to do the first long haul with the trailer. I get the fact that what I have invested is a lot but the other part of the answer I was hoping for was the long wheelbase I have and the amount of sway off the 2 point. I'm still learning about my truck as well and it supposably has a feature that helps in the sway.
I would buy the Hensley but if the Equilizer is a close equivialnt then I would rather go that way. If the Hensley is an investment I get that too. Just weighing the options. I would take the plunge on the more expensive considering but if it overkill I would either stay where I'm at or at least go the Equilizer.
