WNYBob wrote:
Here are two other things to look at to minimize sway.
1. What tires do you have? P tires have soft side walls that encourage sway.
2. TT suspension wear will also allow sway. I replaced plastic bushings with bronze and wet bolts, also upgraded the equalizer with a DEXTER EZ-Flex. This reduced my sway!
I have Goodyear Wrangler Fortitude HT tires. Not sure but don't think they are passenger rated but they are not LT either. I plan on wearing these out before I spend $1,000 on LT's. I will make sure to add air to the top of what they rate prior to towing.
