LamboDesigns
Feb 16, 2017Explorer II
Re: Electrical help please. Lance harness to Ford truck
I haven't picked up the camper yet but I have wired the lance plug in so from my notes.... 2016 ford f250 lariat. I can't see your pictures but assuming they are the same 6 pin and 2 pin plugs I have.
Wire --------------Lance-------Ford
Parking lights-----Green-------Brown
Left Turn----------Red---------Yellow
Right Turn---------Brown-------Green
Backup light-------Yellow------Gray w/black stripe
Brakes-------------N/A---------Blue
+12----------------Black-------N/A wire gauge too small
Gnd----------------White-------N/A attach to frame
I ran the 8 gauge wire to the battery with a 40 amp circuit breaker. Again I haven't hooked up the camper to verify it is right but it did check out compared to the lance manual. I don't have the 7pin harness so I'm also assuming the wire colors on the harness are the same as the truck side.
Looks like the formatting doesn't translate so they aren't lined up but I think you can figure it out.
