RetiredBeanCoun
Sep 06, 2019Explorer
camperdave wrote:
I'll assume there was one more step, remove the existing converter.
That's a sweet inverter setup. All in one charger, inverter, switch yes?
Did you retain any charging from the truck to the camper? Probably don't need it with the solar, right?
The charge from the truck, I kept as it. I have duel heavy duty alternators so I assumed they could stand it. The concern might be the existing cabling since I would assume the lithium will pull a bigger charge, but it is fused and seems to be okay.
44,055 PostsLatest Activity: Dec 23, 2025
