87bob
Mar 11, 2013Explorer
Eternabond?
I am re-roofing a 1996 Jayco Eagle and for the vents and other projections through the top and sides of the unit I am considering the Eternabond product what is your experience with it?
westend wrote:Jerry9n wrote:Exactly!
It's great. Used it on all the penetrations and seams on our roof. Make sure the roof is clean and you use plenty of pressure.
Also, you can use a caulk like Pro Flex along edges and joints if you wish.
Tip: When you're done and everything is sealed, pressurize the interior with a blower and spray soapy water over the exterior. Every pinhole will turn up.
A pin hole exposed:
