Just curious, I thought all the AF campers had the same size generator compartment. My Honda 2000 fit, but just barely, so I dropped the floor of the generator compartment another 2 1/2". I just welded some straps to the angle iron supports that held the floor up, and bolted those straps to the original holes. I then went to the local boat dealer and had a sheet of 3/16" aluminum cut to fit the floor. The floor of the compartment is 10x times more rigid now than with the plywood that was in there. I can post pics if you need them.
