Similar situation. I have a lot of experience backpacking but DW wants a bear proof shelter. I want to still go to off grid places. Our TV is a Toyota Sienna. So all of those make the a-frames attractive. On youtube there is a gent named 'slim potato head' that seems to have a lot of 4 season fun with his older model.
Storage is worse then other RV's but better than tent camping
Set up is faster than tent camping
Hard sides extend season and keep big critters at bay
My questions:
A Jayco model has RV furnace and A/C that provides cooling and heat. I understand you need big power to run AC. But I know the furnace requires power too. Not sure how long you could run the furnace off of batteries. If I need power for both why have both? Furnace, as name implies, better for heat if you have hook ups?
And does a propane furnace contribute as much to condensation as portable propane heaters?
I am pretty sure I see some delamination or water damage on some of the used models. So need to stay up on preventive maintenance it seems. Not sure if there is a make with a fiberglass or aluminum roof/wall. Not sure if that is the cure.
