allright everyone... i managed to find the furnace.. had to pry up some things.. it was in the "box" with my water storage tank.
its seems to have been tampered with in the past, but nothing to where it would affect anything..
I checked all wires for power.
Black wire- + 12.7V
white wire- - V
brown wire/insulation with two wires (thermostat by my judgement)
--one had constant 12V.. the other gave out 12V when i turned the thermostat on...
so power was there, but nothing was happening... so being curious me, stuck my little fingers into the end of the blower motor to rotate it a bit. all of a sudden it started to rotate but immediately got jammed again. then a loud electonic buzzing etc. because of it being stuck.
i went right to the control panel and shut off the power to the converter.. waited, then kicked it back on just because- as soon as i did the fuse blew for the furnace..
when i put my fingers in the blower (power off this time) its obviously jammed up and the whole motor/blower is sitting in loose causing it to hit..
my next problem is.. how do i get the outer case off to try and fix it.... it looks like i might have to disassemble and remove the assembly.. which is something id really prefer not to do... :(
