Adam-12
Mar 12, 2014Explorer
Double_Haul wrote:
I have an 2004 2500hd and have had no problems. I too was freaked out with all the posts. It's hard to explain but the ones that failed did not have a plate that mine has. You have the square reciever which is welded under a couple of vertical plates. Between the plates there should be another plate kinda filling the void. I think if you do not have that plate you could have a problem
I welded a piece of c-channel to my brother's '06. Not because his hitch was failing, but because he didn't want it to fail "eventually." I'm not positive, but I believe the '04 and 05's had a slightly different design than the '06. I know it looked different from my '08.
44,059 PostsLatest Activity: Mar 18, 2026
