grovegang52
Apr 25, 2014Explorer
Bull Rider wrote:
Just to check your procedure, you're attaching the sway device at both ends, and then tightening the hand crank fairly tight? There will be a little wiggle until you compress or tension the device. It should then be fairly snug. If it's not under compression or tension is will feel a little loose.
Yes, that is correct. I guess I just figured it would not move at all, with the exception of sliding in and out. Thanks for the advice.
44,066 PostsLatest Activity: Apr 10, 2026
