DragonSpirit39
Apr 30, 2025Explorer III
Just looking for info.
I and my fiancee are transitioning from a rental home we can no longer afford to a travel trailer full time. I'm in the Mississippi area and need to stay between Batesville, MS and Hernando, MS. I ca...
- May 02, 2025
Assuming you are on shore power (plugged in at a campground), it should be fine but you will have to manage your power. When you want to microwave something, you turn off the aircon for a few minutes and you will have to run the water heater on propane.
A good item to have is a "kill o watt" plug in meter (or similar). This will allow you to confirm the actual wattage of devices. A gaming PC may have modifications so better to get actual data while running a processor heavy game. Also, a good idea to leave it plugged in to watch the voltage. Many campgrounds suffer low voltage on peak summer weekends when everyone is running their aircon.
