no2tracks
Jan 12, 2015Explorer
Caveman Charlie wrote:\GordonThree wrote:boulderado wrote:
Does anyone have a recommendation for an LED replacement tail light for trailer in signature? The bulb seems to be a 3-in-2 design with two filaments (brake, turn and regular light). Thx.
I purchased my two-way 1157 replacement from Superbrightleds.com ... I can't bring up the site right now or I'd link it for you.
It has a "head" that rotates 180 deg, so I can regardless of how it bayonets into the socket, I can aim the light outward. It's bright and then gets even brighter when the brake / turn indicator function is called for.
I'm sure there's one on a popular auction site, direct from China for under a buck, but I'm happy with the one from superbright.
Only downside, the left hand tail light has a clear window in it, so the light also illuminates the license plate with white light, well, now that light is red.
I see that on a car they recommend a special flasher to get the turn signals to flash at the right speed. I wonder on a TT if that is needed? You would have the vehicles tail lights to give you the required resistance after all.
Not needed on a TT as the TW already has the correct resistance and the TT is extra load.
44,056 PostsLatest Activity: Jan 19, 2025
