ktmrfs
Jul 24, 2014Explorer III
Re: Making "Run Flat" tires?
I prefer using a TPMS for trailer tires. Green stuff makes a real mess inside the tire. With a TPMS in the vast majority of cases you'll be alerted to the most common failure mode, a slow puncture, before the tire looses so much air that it results in a blowout. I have mine set to alert me if the pressure drops 10psi, or temp rises above a set point
