brmiller
Jun 26, 2019Explorer
Old-Biscuit wrote:
Couple simple things to verify
With AC Power connected to TT
1) If you turn 'selector switch' to AC and the AC Thermostat Control set to any temp setting does the 'AC Indicator Light' come ON????
YES.then AC Element should be getting hot
NO...then need to:
*Verify you have AC Power at the fridge terminal block
**Verify that the AC 3A in line fuse is good (on output side of terminal block)
AC Heater Element is direct control....No DC control/DC required just AC Power
With Propane Valved in service
*Light off stove top burners on high to establish propane demand/flow
1) Turn 'selector switch' to GAS --- AC thermostat to OFF ---turn Gas Control to High Flame
PUSH and HOLD Gas Control IN .... Rapidly push Piezo several times for five seconds......Does the 'flame meter' move to GREEN?
May have to repeat several tomes until gas flow is present/established
GAS is all manual controls.....no DC Voltage required
Norcold N305/306 Owners Manual
Read up on how your fridge operates
WOW! Thank you for the quick reply and all the suggestions. I will dig in to this later to day and see what I can figure out.
44,025 PostsLatest Activity: Feb 26, 2025
