gordfromborder
Oct 09, 2014Explorer
Hello Skydiver31,
I feel your displeasure with AF. We purchased a 27T ( factory order ) in January 2014 and took delivery in May when we returned from down south. ( we are retirees in Alberta, and before I get flamed, I will change my signature details ). I did a two hour PDI and had a list of 30 items that the dealer fixed prior to delivery. Since then we have added at least 50 more items!
We are experiencing similar issues that are just as frustrating. It's great AF puts greaseable fittings on the suspension, but after one of the zerk fittings fell out, I checked the others. One more ready to fall out and four extremely loose. Broken welds on the aluminum lower slide out frame that has been fixed with metal strapping and sheet metal screws that keep loosening, leaky shower door retraction mech., saggy recliner that has to go to an upholstery shop, hide a bed that couldn't be used because it couldn't be fully opened without contacting the kitchen cabinet, uneven and poorly installed sink, broken ground wire...........and on and on.
My dealer, Tee Pee Trade in Camrose has been great to deal with and AF has been authorizing most of the repairs in a timely manner, but our trailer has been in four times since delivery and goes back on Oct 17 for more service work. The final one before we head south.
Now am I being too picky? Maybe, but when we pay a premium for an RV that we expect to be better than average and end up with less than average, I am PO'd.
Like skydiver, I have taken to doing numerous fixes and improvements that should have been caught by AF or better design and or execution by them. I have completed mouse proofing. My latest project is as a result of the mouse proofing. While under the trailer, I noticed the coloplast ( plastic covering material ) was very saggy under the front holding tank ( grey water). When I pushed up on it, water started running out the " drain " hole in the plastic. I have removed the panel to expose both tanks and as suspected the fibreglass is soaked, turning black plus rusting the light weight steel frame cross members. I have added tank supports and am putting in 1" styrofoam rig in insulation. After I replace the coloplast all joints will be sealed with an asphalt type car undercoating spray.
Anyways, enough complaint for now.
Gord
Gord
44,025 PostsLatest Activity: Feb 18, 2025
