rmoparman wrote:
Going to look at Arctic Fox 27 l this morning. All of reviews i have seen , best owners forums says hands down. Not alot of bling but fit and finish top notch. Not no dealers on east cost but one in PA.27 l is to small for us. Would like to order a 29k or T. Might be to heavy for 3/4 ton.
It depends on the model year/specs of the 3/4 Ton truck and the model year/specs of the AF 27-5L. The newer 3/4 Ton trucks have specs fairly similar to the older 1 Tons (like my vintage 2004.5 Dodge Ram 3500). I also have an earlier model 2011 AF 27-5L before they lengthened it a bit and widened it. The GVWR on my AF is 12000 lbs. Dry weight really means nothing. My truck has a GVWR of 9900lbs with a cargo capacity of 3020 lbs (before passengers, dog, hitch and stuff in the bed). I feel like this trailer pushes the limits of my truck. It is really heavy. And the new ones are even heavier - as you can see from the other threads. I wouldn't feel safe pulling anything heavier than this AF with my truck. I wouldn't even consider the 29-5K with my truck. I think you're probably in 1 Ton dually territory with that trailer.
