thetundrawolf
Sep 17, 2014Explorer
MM49 wrote:
I would suggest that you have an installation problem. Hopkins is a very well respected company in the RV business,
MM49
Did you read what I said? Really? I went off of my original wiring and the older one worked. I double, triple, and quadruple checked my wiring. Using an 1156 bulb and harness to simulate what I did.
Going from the input wires I had a BRIGHT LIGHT from the 1156.
Going OUT OF THE CONVERTER I had dim, almost unrecognizable light. I used an artifical ground just to make sure that part of the frame, what was also used to tail light grounds (I used the supplied connector with the converter. I cleaned the metal to a shine.) and still no output from all three converters.
Well, you can believe that. If you get one and have the same problem, it's not on me. I warned you.
44,027 PostsLatest Activity: Mar 12, 2025
