kcstrom
May 14, 2022Explorer
GrandpaKip wrote:kcstrom wrote:GrandpaKip wrote:
Maybe I missed it, but have you looked at the door sticker on your truck?
Yep. It matches the info from the towing capacity sheet I included before.
GAWR: 3900 for both front and rear
GVWR: 6800
Requires PSI of 39lbs/in in tires.
It doesn't state an actual weight from the time of manufacturing.
What about the payload?
-It doesn't say anything about payload or measured weight at manufacturing. Only the GAWR and GVWR and require tired pressure.-
Edit: I looked again and found there is another sticker on the body inside the door, apart from the stickers on the (end of the)door itself. This does state a payload of 1139. You learn something new everyday!
So, this indicates it had a known difference of (1390-1139 =) 251 from what the spec sheet says. I guess additional options or just variance in weight as manufactured account for 251 pounds of mystery weight. Only ~300 more to find! lol
