Re: Ram 3500 DRW tire pressure
Since you are going up significantly in weight if anything tire pressure would go up. But since 80 psi is your max tire pressure (unless you are running 19.5s) you are already there. If anything you could consider adjusting your pressures down a bit.
No RepliesBe the first to reply
