Jack_Hart
Jul 21, 2017Explorer II
I've got an Apex with the same problem. While the wood strip is not structural, the fact that it's coming loose indicates that the roof is sagging. While a little sag is probably to be expected with age (my camper is 15 years old), it's not going to be cured with just a bigger screw or better adhesive. My solution was to remove some of the roof sag by shimming the roof back up with a slice of Starboard between the roof and the "roof rod". Once the sag is removed, a bigger screw and more adhesive will hold the wood piece in place. Hopefully this temporary fix will work for another five or ten years.
44,030 PostsLatest Activity: Feb 03, 2025
