OleManOleCan wrote:
jay427 wrote:
afidel wrote:
Would be nice if the TT was small enough that I would not have to mess around with WDH's etc. Just quick hook up an go.
That's not really an option, my TT is only 18' and there's no way I would tow it without a WDH with sway control. Even behind a 2500 it moved around more than I liked and that was without wind or panic maneuvers. To each their own but I'd never tow a TT without sway control. That said putting the bars on or taking them off takes maybe 30s so it's not like it has any meaningful impact on our setup and tear down time.
I suppose it depends, our old 20' TT behind the our old 2009 2500hd did not care if the WDH was on or off. With the 1/2 ton we used the WDH half the time, less 100 miles runs I did not even mess with it. Each trailer does pull different for sure.
I get what you are saying about the time deal, it just seems like it takes forever when is raining out. I was using a Rigid Hitch and swore getting the bars on took a few minutes by the time I dug out the bar, set the pins, jack the trailer up to get the bars on, etc. Granted this was 7-8 years ago so my mind is foggy:)
When I had a 30' trailer I used WD bars.
Now I'm towing a 20' w/o bars.
My HD F-150 Echoboost is a beast for towing.
My camper only weighs 3300 lbs, and I'm using a Reese 6000# hitch.
Set it up right, put on E-rated tires. Pay attention to air in the tires,
and go, go, go. You also have to pay attention to weight in the bed of
the truck and how you load the trailer.
Years of towing make a big difference deciding when towing is set up
just right.
yep, that's about my experience as well. Based on our truck and previous TT's our 20' TT was a give and take with the WDH, we never pulled it over 300 miles and that would have been a long haul at that.
