raybuckner
Feb 09, 2024Explorer
Do you know if there is a way to split at the plug under the dash to hook up both antennas so I don't have to switch it back and forth?
Tango424
Feb 21, 2024Explorer III
What plug are you talking aboit? The antenna connections? raybuckner Depends on the connectors on the cables if it is a stick in type like a car radio you could do a y cable but may cause issues you could get or make a antenna switch which would work better theyre easy to make if you understand basic electronics and can solde
44,030 PostsLatest Activity: Jan 20, 2025
