- Yeti_plusExplorerI tried those magnet mount antennae. Did NOT work on my 2014 Chev. I tried 3 of them.
I bought this and I am getting about 3 years of use. I have a piece of aluminum flat stock, that I drilled a hole in to fit the antenna, then fastened to truck by removing a bolt and then replacing it holding the flat stock in place.
Brian - ssthrdExplorerThis is for my particular camper. Yours may be different.
It’s sitting on a ¾” stall mat, and I have about 5 ½ “ clearance over the antennae and about 7 ¼” between the cab and the overhang. 51” from bottom of camper to underside of overhang.
Hope this helps. - JDemersExplorerThanks for the replies. SSTHRD thanks for the link to install a new antenna. A lot of helpful information.
- ssthrdExplorer^^Neither did I, but I believe that the camper's aluminum frame interferes with reception. Everything works fine without it. I have not looked into a fix for that, but I'm sure there is one........
EDIT:
Seek and ye shall find. I know this doesn't answer your question, but I found a solution to my concern here
I will measure the clearance I have and post tomorrow. My guess is about 3". - LadyRVerExplorer III didn't have to.
44,071 PostsLatest Activity: Aug 30, 2026
