TxGearhead wrote:
covered wagon wrote:
maxum1989 wrote:
kohldad wrote:
We use and my father uses an elastic roof sealant paint. He has used it on his 97 Snowbird since the first crack in about 01. He paints the seals each or every other year as needed. If interested, I can get the exact name and more information when I'm home and can reach the can on the shelf.
This is what I do on my Northern Lite. Built pretty much the same as the Bigfoots.
I mask the edges with the blue tape and do the same thing except I use a soft caulking called SONOLAST because it is very good caulking. Stays like rubber and holds good for years. I use a stiff brush and spread till smooth going both directions for better adhesion.
I don't like the Eternabond tape idea because I think it would leave air gaps underneath going across small gaps or compound bends.
So y'all are coating the entire roof? Is this SONOLAST a caulk and you are brushing on the entire roof?
I'm not coating the whole roof. Just tape off around the vents and such and "paint" on the coating of your choice. The Elastic roof cement works great for this. This roof coating stays quite flexible. The original coating Northern Lite puts on gets very brittle, flakes and cracks with age. My goal was to cover as much as the original coating as possible.
