rugerguy
Sep 25, 2013Explorer
I've found side to side movement is usually in the springs or tires.
Radial tires being worse.
Had this problem on my old 5ver after putting radials on.
Solved it by putting stabalizer jacks just behind the rear wheels to take the weight of the axles.
You can experiment by using a couple hydraulic jacks to see if that helps before you go to the trouble of installing the stabalizers.
44,055 PostsLatest Activity: Dec 23, 2025
