Re: Smoke from Tow Vehicle
Hot brakes have a definite smell that you would recognize. I would think more likely the exhaust system getting extra hot from the climb, causing the rust treatment to burn off. It is also possible something plastic, or other debris stuck to hot exhaust, that burned off.
Only 10K miles, there should be no mechanical issue, causing heavy smoke. We need to drive our TVs more, mine just turned 10K also. :)
Jerry
No RepliesBe the first to reply
