I took my Dodge 3500 to the local Dodge dealer for a tire rotation today. They said that they couldn't get the lug nuts loose on the rear duallies. They tried soaking them with penetrating oil but the...
I believe the nuts are steel as well as the studs. They did mention that they may need to heat them up. I use anti seize on everything and will put it on the studs if I get them off. I have been spraying them with Liquid Wrench since I came home.
So for right now I am just soaking my nuts, hoping for good things to happen.
