texasdiver
May 30, 2015Explorer
twodownzero wrote:texasdiver wrote:twodownzero wrote:
You should not consider any non-dually truck, and should even consider an F450 or 550.
The HUGE difference betweeen an F250 and 350 is payload...and you need to maximize that to be able to tow ANYTHING with a camper on.
Geez....I'm talking about dropping a 900 lb camper onto an F350 SRW truck and pulling a 5000-6000 lb camper with it that has a tongue weight in the 700-800 lb range. Obviously those are dry weights and there will be people and gear but still.... that should be well within the range of any properly equipped 350/3500 SRW truck.
I bet there are a bazillion guys out there towing camping trailers with trucks that have that much weight in gear and fuel on the bed.
My 1 ton SRW has about 2700 pounds of payload. But it is a diesel, stick, 4wd, and 4 doors. A regular cab 2wd with no options could probably do a whole lot better with single wheels, but where have you seen one of those trucks for sale or on the road, anywhere? They're not common anymore. They once were the norm!
My truck would probably be overloaded even with the camper you describe if I had loaded it for even a 5 day trip. That said, I'm also skeptical that there exists any 900 lb hard side camper for a full size of any kind, and even a pop up with a bathroom is going to probably be several hundred pounds heavier than that.
Newer trucks have higher payload ratings, but if you have a 4 door truck with 4wd and a diesel engine, it's hard to stay within the GVWR with any trailer and a hard side camper.
A DRW is the answer. Especially a 1 ton so you can get a numerically lower rear ratio so as not to waste too much fuel, since carrying a camper doesn't really require deep gears.
I'm talking about a lightweight aluminum popup like this with minimal interior to basically give the kids a place to sleep and hang out. The spec sheet says dry weight is 895 lbs: Four Wheel Hawk Popup Camper not one of the 3500 lb hard sided models with slide outs that some of you guys are using.
44,025 PostsLatest Activity: Feb 18, 2025
