CoupleOnTheRoad
Jun 03, 2014Explorer
RCMAN46 wrote:CoupleOnTheRoad wrote:Terryallan wrote:
You will be OK on a short flat trip. But do keep it out of OD as that will cause the trany to get hotter.
I doubt your 2001 has tow haul. So just lock out od and ride.
BTW. I believe you will find running in 3RD gear will be a better more pleasing driving experience anyway. Not only does the trans stay cooler, but you have much more throttle response, and the MPG is the same, as the engine is not working / lugging, so hard to stay in OD.
My Yukon has a tow/haul button. Use it I assume? But keep in 3rd gear?
With the tow/haul I would just let the transmission pick the gear. That is what tow/haul is all about.
Ok great. Thank you.
44,025 PostsLatest Activity: Feb 18, 2025
