jeffmx5ExplorerDec 03, 2016What is this drain?First time winterizing the camper and I find the fresh water tank drain with a second hose next to it without a valve or cap. What is this, is it an overflow for the freshwater tank fill? Show More
brackleybeachExplorerDec 03, 2016What overflow? If the fresh water tank is full it will blow back at you through the fill pipe.
Related ContentGrey water tank won't drain completelyHelp - jacks are draining my batteriesBlack tank not draining!Low point drainsClogged Drain
