SJones37
Jun 28, 2013Explorer
For the 10 minutes it would take, ide put a jack under the axle and get the tire off the ground.Then you could put a bar under the tire and rock it and see if its a bearing .Check lug nuts,might have a couple loose ones.For the little time it will take to check all wheels its worth the piece of mind.Before i spent 350 on a shop ide do some looking first.its pretty easy to pull bearings,clean and repack.Its a little messy but not to hard.
44,029 PostsLatest Activity: Jan 28, 2025
