You didn't mention the 5.4 motor. Probably because you know what it can do. I have a 5.4 in small class C and it leaves our driveway at 12,380 pounds. Not a ball of fire but takes us everywhere we want to go. It's in a 1 ton, yes braking on some roads takes some thought. I usually take out of overdrive and no problem on steep down grades keeping under control or better said, to avoid using the brakes to much.
P.S. also I carry spare fuel filter and cop.
For whats its worth...get a tubing cutter ($15.00) for air lines when you install them. I used a pocket knife and chased air leaks for quite awhile. Tubing cutter cuts nice fine cuts not jagged.
And I use a bicycle pump to put in 40 psi in my pick up when using the TT, that decision was made after pricing out in dash air fill system with reservoir tank and all the do-dads. I mean geeez, 1/4 inch air line, not a lot of volume required. But my pump will not do the neighbors air bags, he puts in 80.
