blt2ski
Apr 13, 2021Moderator
I have/had an older sister that towed an older Cub Cadet from the 50s with two different Toyota's. One iirc was a smaller chassis, 3500 tow rating, other a bit bigger with a 5k rating.
She upgraded to larger as the smaller was capable power wise etc, bigger was better overall. She was typically the only one in vehicle.
Based on a few comments, never followed my advice, she needed trailer brakes on trailer. If the trailer is over 1000-1500 lbs, I will HIGHLY suggest installing brakes. She went through vehicle brakes quickly, and had a few what I would call white knuckle braking experiences. Trailer dealer may not say you need brakes, legal in yours or my states may not say you need brakes, same with Toyota warranty.....out them on!
Unfortunately she passed on 3-1 so I'm not able to get a y more specifics. While a lovely sister for 50yrs, unlike her father who was a brilliant engineer at Boeing, she was a librarian, not too mechanical. Even at that, not real smart from what and how she needed to tow properly or correctly.
With above said, an areodybamic trailer should be towable with a hybrid. Like a non hybrid vehicle, the one with the larger motor, more fears in transmission etc will tow up hills etc faster.
Good luck with choice.
Marty
Marty
44,071 PostsLatest Activity: Aug 16, 2026
