tatest
Nov 03, 2014Explorer II
If there is an option of fiberglass vs aluminum skin, the TT is most likely stick built, not laminated, so there is nothing to delaminate.
If you are talking about two different families of trailers with almost the same name and similar floorplans, then one family might be stick built and the other laminated construction. Not a skin option, two completely different TTs. Jayco sometimes does this with names, 2-3 model lines starting with name Jayflight, 2-3 lines starting with name Eagle.
44,056 PostsLatest Activity: Jan 19, 2025
