Downwindtracker2 wrote:
When guys and gals are looking at purchasing a TT,they look at the brochure . But to get an idea of reality, our brochure weight dry was 4100#, the factory out the door sticker was 4600# dry ,when I ran it over the scale,fully loaded for an across Canada trip,the two axles were 2830 kg.(2.2lb=1kg).
This is all a so what to me, I switched out the axles to 5200# and the tires to either 2700# or 2900# truck, 16" 10plys .And I pull with a diesel 1ton. But someone with a 1/2 ton, might not have a so what attitude driving down the road.
Dry weights are useless but that's the TT industry for you... What brand/model of TT and what GVWR? That's a cargo wt. of 1639 lbs which seems rather high to me for a TT that is probably around 20-25'. Was it weighed correctly at a scale with a min. of 2 passes, one with truck only and one with spring bars removed (and in back of truck)?
I did a detailed weighing at a scale after picking up our TT new at the dealer. It is 29' long with a 6800 lb GVWR. The weight of all cargo for the two of us plus the weight of all mods & upgrades came to only 674 lbs on top of the factory out-the-door UVW (on the white sticker inside a cabinet). It sounds like you ordered the TT with some factory options that added 500 lbs? Are you towing over the GVWR sticker figure (like us - see below)?
Upgrading axles, suspension and tires is a good thing to do, esp. if doing a lot of long distance mileage ("kilometerage"?) But the frame is also a consideration since some are weak and flex a lot and some are very strong in comparison. Many TTs out there are manufactured and sold with axles and tires that are running near their max. ratings which can lead to problems like blowouts and bent axles.
Our TT has a custom one-off HD frame from the factory with 2 @ 5200 lb axles that added about 500 lbs of wt. All the factory did is reduce the CCC to a pitiful 930 lbs instead of assigning it a new GVWR. As a result, we could at times be towing over the "official" sticker GVWR figure. Our real GVWR is unknown but is probably more like 10,000 based on the axle rating and stronger frame making the CC more like 3000 lbs. Way to go KZ.
