sh410
Oct 18, 2015Explorer
The specs you are looking at online may not be accurate. For example: curb weight can be for a stripper model. Go to a dealer and look at several trucks might interest you. and check on the door jam for max load.
Ideally, first select the trailer you want and take 20% of the GVWR of the trailer. That will give you the Pin weight. Then go find the correct tow vehicle to pull it.
I may be 2500 or 3500 or a 3500 dually. (Ford: F250 or F350)
Then the question will be gas or
44,029 PostsLatest Activity: Jan 28, 2025
