Cummins12V98 wrote:
6.7 tow rig wrote:
Cummins12V98 wrote:
This is an example of buying a new truck and then wanting to make it more capable. Simple solution buy the correct truck first. 3500 with factory rear air ride would have possibly met the needs.
Probably the most ignorant comment I've heard in awhile. If I wanted a 3500 I would have bought it. If I spent 70k dollars on a truck I don't think the 900 dollars more for a one ton would not have been a deal breaker. I bought a 3/4 ton because I wanted the rear coil springs because of the improved ride quality. Keyboard warriors like you that don't answer the question asked offer NOTHING of value to this forum.
WOW, a little testy??? "Ignorant" that's a fine comment. My comment was NOT directed at YOU since YOU already did what many do. It was to HELP others not make the same mistake.
But hey thanks for the other comment "keyboard warrior". I will add it to my collection.
You had no answer to his question, and no clue to why he wanted airbags, but you chose to insult anyway , yes an ignorant response. You assume he made a mistake, and again you had no clue.
HELP others not make the same mistake, really , now what mistake would that be. :h
