westend wrote:
handye9 wrote:
I have a wired system, that is on, any time I have it plugged into power outlet in the cab. Purchased individual pieces on eBay.
Here is a similar monitor. It clips onto my rearview mirror. Got parts from Radio Shack, to make a power plug.
Here is a similar camera.
Here is a similar video / power cable. I wired truck and trailer, individually.
I also, have one camera mounted on a piece of aluminum that slides (for hitching up) under the license plate on the truck.
When I hitch up, I plug in (in truck bed) the hitching camera. After hitched up, I unplug hitching camera, put it back in storage compartment, and plug in camera on back of the trailer.
How does your DIY system perform? Would you upgrade any of it now that you've had it in use?
This is about the cheapest combination I've seen. Thanks for posting!
Can't think of any upgrades, I might do now.
The last upgrade, was wiring the truck, so I could plug in in the bed. When I started using the system, I ran the power / video cable through the cab, out the rear sliding window, and through the truck bed. Now I just open the tailgate and plug in.
This is second TT that I've installed it on. I've been using this system since 2005. Over the years, I've replaced a cable (or two) and a camera. I also have a camera on my truck camper.
With the camera on truck bumper, I can back the hitch ball under the coupler, first shot. Hooking up alone is fast and easy.
On the road, the camera on the trailer shows me what is going on behind me. On rare occassions when I pass some one, I can see they are behind me, even when side mirror looks like they are still beside.
On bottom of the trailer, I mounted (front to back) a one inch PVC pipe, which is the conduit for camera cable and wires for self installed back up lights. When I needed to replace a cable, I just taped the new one, to the old one, and pulled it through the pipe.
NOTE: If you are going to install a rear camera, put it up high as you can. Then point it down at an angle.
My first install was on the TT bumper, pointed straight back. I had a lot of glare from the sun.
