JRRNeiklot's avatar
JRRNeiklot
Rear hitch rack battery bank
I have installed a custom heavy duty hitch rack on the back of my 33 foot travel trailer. I have a battery box mounted there with six 6 volt batteries, charge controller, and inverter. Probably weighs 400 pounds. I didn't think it through when doing this and now I'm concerned that may cause sway or worse, be too much weight for the bumper to handle. It's a heavy duty bumper, and seems to handle it fine atm, but that's sitting in my driveway, not bouncing down the road. The rack has been welded to the bumper, but not the frame. Is this going to cause issues? The only other place I could put the battery bank is in the pass through storage under the bedroom, and I'm hesitant to do that due to venting. I'd hate to wake up dead!
As always, I'm grateful for any advice.
  • For the structural strength, I'd take it by a welding fabrication shop and have them look at it. The load may be secure to the bumper, but is the bumper attached to the frame well enough to handle the load?
    For the tongue weight you'll just have to judge that yourself if you can't find a scale. Hook it up to the TV on level ground, does it look like the rear bumper of the TV is the same or higher than when previously hooked up?
    If it doesn't look like the rear bumper of the TV is raised a lot, take it out for a drive and see what happens slowly increasing the speed. You might have someone else follow behind in another vehicle to watch for weird movement or sway that you don't see.
    Bill
  • You could move the batteries to the storage area and make sure it has proper venting. Having the inverter and charge controller in a sealed box with batteries isn't the best, either.
    FWIW, I have five batteries inside my trailer but have installed venting so I don't have any worries. I did this expressly to locate them near the axles so that tongue weight isn't radically affected.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Many decades ago I made the mistake of putting 300 lbs of heavy parts I'd bought in the back of my Airstream.:S At 45 mph it tried to take me to the scene of the accident. This was in the days when you had to move the handle to put the trailer brakes on which I did while still accelerating. Once the swaying stopped I'll was able to slow down... stop and move half of the items to the front. Once was enough and to this day when in doubt about having enough tongue weight on an equipment trailer I'll give the steering wheel a little wiggle at 45 mph with my hand on the manual brake control to see if it's going to get interesting.
    AGM batteries do not need venting and putting them close to the axles will be cheaper than a new trailer and TV. You can still use your rack for bulky items.
  • I see a few risks. Lighter tongue weight could cause more sway. 400 pounds on the bumper that may not support it. And all the money where it can be easily damaged by someone rear ending the trailer or backing into something.
